Dynamic intake pressure measurement
Didn't know where exactly to put this - it is more of a data logging question than an ECU one.
What I want to do is to measure the dynamic pressure in the intake port.
At 6000RPM we have 100 rotations/minute.
So I would like to have pressure at every 5-10 degrees of crank angle for one cylinder, which equates to a pressure reading rate >= 7200Hz.
Are there pressure sensors that can do this that are normally used?
I almost think I could use a microphone - but that last thing it would hear is the fuel covering it before it got sucked into the intake valve...
Surely someone is doing, or has done, this?
