Q on Lambda
Maybe not the forum to ask, I have an M130 LTC and Bosch LSU
I searched here and online, could not find any answer
From factory the car has a narrow band sensor , adding the wideband ; will this make the OE narrow band obsolete or would the ECU still make use of the OE narrow band?
I presume unplugging the OE unit will have zero affect to the ECU
As per motec website , is it correct I need to calibrate my wideband sensor every X km ; will the ECU indicate if the sensor needs replacing or are you best going by mileage
