EGT Sensors to Autosport connector?
PostPosted: Tue May 30, 2017 6:57 pm
by CNDat510
I'm wondering if these EGT wires can be cut/ shortened and passed though an Autosport connector on the firewall. They'll be going to a Race Grade TC8 mounted inside the car.
-Thanks
Re: EGT Sensors to Autosport connector?
PostPosted: Tue May 30, 2017 8:38 pm
by AdamW
Yes it can be done provided you use the correct terminals. They need to be Alumel and Chromel and they are available in size 22 for the standard AS connectors. Note wire needs to be proper "compensation cable" also to minimise cold junction error.
PostPosted: Tue May 30, 2017 10:02 pm
by Scott@FP
The extension wire (and connector terminals if possible) needs to match the TC type. T, K, J etc. all use different wire.
You can get TC type specific bulkhead connectors.
PostPosted: Sun Aug 27, 2017 10:13 am
by CNDat510
Hey guys, sorry for radio silence, somehow I lost track of this thread and missed your replies :oops:
Thanks for the taking the time to respond, this helps immensely.
-Cory
