Injector driver question m800
PostPosted: Fri May 19, 2017 7:50 pm
by msgofast
can an injector drive on the ecu fail in a way will drop out the injector under high load and but ok when light load?
ecu sustained a crash that cut the loom, so thinking maybe a sort killed something in the ecu?
thanks.
Re: Injector driver question m800
PostPosted: Sat May 20, 2017 8:43 am
by stevieturbo
Unlikely, but I guess anything is possible.
Is the injector signal stopping at higher loads ? Which cylinder ?
PostPosted: Mon May 22, 2017 10:31 am
by msgofast
unsure if it's an inj or plug, it's too clean off and on to be a plug.
need to get the board tested.
PostPosted: Mon May 22, 2017 2:07 pm
by SprinterTRD
Just do a injector test under "Utilities" "Test output" crank up the RPM and duty with no pressure in the fuel line.
If it works there then its not the ECU.
PostPosted: Tue May 23, 2017 5:21 am
by stevieturbo
msgofast wrote:unsure if it's an inj or plug, it's too clean off and on to be a plug.
Then test it. Don't guess.
Get a scope or meter on the output and test/monitor under load. You seem to suggest this is a repeatable problem ?
