engine falls down after rev
hi, we're working on our formula student project.
Our engine is a CB500 with ristricted inlet ( 2cm tube ).
The engine runs good at idle and when we accelerate over the whole rpm range.
but when we rev to high and let the throttle loose, the engine goes under idle rpm and turns off.
the same when we drive and take the clutch, the engine falls down too.
wich setting do we need to check to solve this problem? cause the decel only works shortly after kicking the throttle.
greatings benjamin
student Karel de Grote College
greatings benjamin
