M1 GPR-P Paddleshift setup - Help
Postby karel021 on Mon May 02, 2016 8:38 pm
Hey Guys,
Im trying to setup the Paddleshift function with pneumatic shifter (2 solenoids)
Iv looked over all of the settings but is still missing something out.
When up shifting it works "good" but when down shifting both the up and down solenoid blips, and therefore no shift is done.
Any pointers, the engine hasn't been started yet, but i cant imagine that this is an requirement ?
M150 With GPR-P software
karel021
Re: M1 GPR-P Paddleshift setup - Help
Postby MarkMc on Tue May 03, 2016 9:48 am
I'm not sure how you managed to get both solenoids trigger on down shift I have not found any situation in the GPRP firm ware that could so this. Can you check both switch inputs individually with the digital inputs you assigned them to? Also just check what the actuators with the channels Gear Shift Actuator Up State and Gear Shift Actuator Down State.
Postby karel021 on Wed May 04, 2016 8:39 am
Found a Glitch in my wiring :roll: :roll: :roll: :roll: :roll: :roll: :oops: :oops: :oops:
karel021
Return to Tuning discussions
