DimST wrote:Hello Kip,
You first need to add an AT input switch with parameter: 16 : Ground Speed Limit Enable (for your switch)
Then you will find a fuction called ground speed limiting which is used when you use ground speed limit input.
I believe from there it's quite easy but let me know if you need further help
That I knew mate
The ground speed limiter is working with me but the problem is its sounds horrible , the bike humps up and down ,
I got it on :
rpm limit type 3
randomizer 75
controle range 100
I think the problem is the randomizer numer , the ignition and fuel look like getting cut to long .
I got a 2013 R1 and like you hear on the youtube film I posted that R1 sounds how I would like to get mine sounding when ground speed limiter on .
