Does anybody know how you can get the M800 pitlimiter working like this on the R1 bike ?
You hear limiter kicking in at 14sec point of the video .
https://www.youtube.com/watch?v=4VXqaZmebzw
DimST wrote:Hello Kip,
You first need to add an AT input switch with parameter: 16 : Ground Speed Limit Enable (for your switch)
Then you will find a fuction called ground speed limiting which is used when you use ground speed limit input.
I believe from there it's quite easy but let me know if you need further help
