individual cylinder fuel trim
PostPosted: Wed Jul 16, 2014 1:41 pm
by balligee
Here goes my first post on the forum :roll:
took out the plugs to see the operation of them. so this got me thinking about there apperance !
looked up the egt sensors at peak rpm (5869) would you say egt temps and plugs match ?
pls note that egt 1 has not been working since i fitted the sensors (its on the todo list ) and probably the most important one to answer this ?
would you say adjust individual trims to even this "problem out " or would you think theres a bigger problem with intake manifold flow to cylinders !!!
here is a picture of the engine bay
your thoughts are welcome
regards Gee
Re: individual cylinder fuel trim
PostPosted: Wed Jul 16, 2014 9:33 pm
by AdamW
That is unlikely a cylinder trim issue. Either that cylinder has a serious misfire or you have some mechanical issue - low compreesion, burning oil etc...
