RPM Limit m4
RPM Limit m4
Postby Arvind_D on Sun Jan 26, 2014 6:12 am
Hello guys,
I am currently setting up the ecu for my honda CBR 600 engine 1992 model.
I am stuck at RPM limit.
I would like to know what is it used for and whether I require it.
Any help will be appreciated.
Arvind_D
Re: RPM Limit m4
Postby mstech on Mon Jan 27, 2014 3:49 pm
It sets the maximum allowed RPM (revolutions per minute) that the ECU will allow the engine to do under open throttle condition (this limit can be exceeded but over revving the engine using a incorrect downshift) it should be set to an appropriate value for your engine, start with the one used by the manufacture of the stock engine that you are using and change it from there to suit.
mstech
Return to Tuning discussions
