DBW - Aux Table 1
PostPosted: Sat Jun 01, 2013 4:07 am
by Phoenix
Gents,
Can anyone please explain to me what the below DBW - Aux Table 1 represents, in comparison to the DBW - Position Translation (%) Table..?
Thank you.
Phoenix
Re: DBW - Aux Table 1
PostPosted: Sun Jun 02, 2013 6:45 am
by Phoenix
BUMP
PostPosted: Mon Jun 03, 2013 4:01 pm
by Scott@FP
Get used to hitting F1 key a lot-
The Aux Table is only used if the Function for the Aux Output is set to
one of the following:
Auxiliary Table
DC Servo Motor Control
Cam Control 1 or Cam Control 2
Servo Stepper Motor Control
Fuel Pressure Control / Fuel Pressure Control 100Hz
Mazda RX8 OMP
Thermo Fan Table
Traction Control Power Reduction
However, that doesn't mean the aux table can't be used to output a value that can be used elsewhere.
PostPosted: Thu Jun 06, 2013 2:05 pm
by Mattk@dentsport
First table is a drive by wire throttle table (sets relationship between pedal position and throttle position- note how high ECT closes the throttle down to protect the engine) 2nd is cam angle (ie. AVCS).
PostPosted: Thu Jun 06, 2013 4:20 pm
by Phoenix
Thanks for your replies.
I'm aware of the purpose for the position translation table...im the one who set it up in relation to ECT.
Its just the Aux Table 1 table that has thrown me off, since its on all Motec start up maps for Subarus with AVCS.
I want to remove this table...but, just need to be sure it wont have a negative impact.
With regards to it being related to AVCS, why have this table if there are already Aux Output AVCS tables on hand for both intake and exhaust valves..?
