Some requests..
On ecumanager At the Axis setup screens, the interpolate function doesnt appear to do anything...
Also theDual RPM limit should apply the retard values only when reaching the limit rpm not before, so that if you set it up with a clutch switch you wont retard your timing while at idle before pressing the gas pedal.
