Ignition timing vs Boost vs Power
Postby Martin on Fri Oct 05, 2012 10:52 pm
Maybe someone will find this interesting.
Graph of base igntion map then -3deg, -6deg, -9deg, -12deg, -15deg, -18deg, -21deg
No boost control was done. Its just open loop DC with a boost reference. DC in all runs the same.
Timing step boost.gif (20.62 KiB) Viewed 28192 times
Timing step.gif (48.35 KiB) Viewed 28204 times
Re: Ignition timing vs Boost vs Power
Postby stevieturbo on Sat Oct 06, 2012 9:43 am
They are pretty hefty jumps in timing though.
And it's annoying the way this forum puts pictures into separate small windows.
Postby fel1979 on Mon Oct 22, 2012 2:29 pm
Nice Martin, Is really good to have this kind of comparison.
fel1979
Postby jasaircraft on Sun Mar 17, 2013 5:55 pm
Not sure what I see here, the lower manifold pressure line is making more power? and its the most retarded timing?
jasaircraft
Postby Holmz on Sun Mar 17, 2013 10:07 pm
Would having EGT with those other curves complete the story?
Postby Martin on Mon Mar 18, 2013 4:10 am
What you are seeing....
Most timing, Most power, Least boost
Less timing = Less power = More boost (this is the case for each of the graphs, -3. -6, -9, etc....)
Yes, EGTs would have been good. Cylinder pressure with TDC reference brilliant.
Postby jasaircraft on Tue Mar 19, 2013 5:05 am
Oh ok i see how egts would have been great to relate it to the boost, pressure/ tdc to power output aswell...
jasaircraft
Postby pftuning on Sat Apr 13, 2013 1:28 am
Martin wrote:What you are seeing....
Make sense to me. Nice illustration, Martin.
Peter Florance
PFTuning
Virginia Beach, VA 23454
http://www.pftuning.com
pftuning
Return to Tuning discussions
