If you use Fuel Inj duty % to calculate fuel used, what is the estimated accuracy of this calculation?
I'm using 6 x Bosch 340 cc/min injectors.
TunedByShaneT wrote:Anywhere from quite accurate to not at all.
This largely depends on;
Linearity of your fuel injectors throughout the dynamic operating range
Accuracy of battery voltage offset for your injector at the fuel pressure you are running
Flow variation of your injectors to each other throughout the dynamic operating range
Better accuracy if you calculate the injector duty cycle using Effective Pulsewidth rather than just the reported duty cycle. Still need the above items to be correct however.
