How to Tune Fuel Maps from Logged Data - webinar question ?
Hope this is in the right category as it is related to tuning.
After watching the excellent webinar run by Pete about tuning the engine offline with data logging I was curious to everyone's thoughts and opinions on this subject.
Unfortunately i don't have access to a dyno so all my tuning is done live with someone driving the car for me on the street or using the logging option as discussed in the webinar when driving by myself.
My question is what gear is it best to use when loading the engine for a lambda trace to use for this method ? I would assume that at a given load the lambda reading would be slightly different in every gear correct ?
Should you always use the same gear for each time when doing lambda tuning or is it not so important ?
