Page 1 of 2
Direct injection
PostPosted: Fri Aug 05, 2011 4:30 am
by als
Hi at all..someone have install motec engine managment in any petrol car with direct injection?
How did you manage the high voltage injectors?
Thanks at all
Luca
Re: Direct injection
PostPosted: Fri Aug 05, 2011 1:39 pm
by Gaston
Hello Als !
Is this a Common Rail Diesel Engine ? Or FSI (regular fuel) Engine ?
PostPosted: Fri Aug 05, 2011 5:55 pm
by als
is a regualr fuel egnine type FSI
PostPosted: Mon Aug 08, 2011 6:07 pm
by als
someone have any suggestion?
PostPosted: Tue Aug 09, 2011 12:10 am
by Mazi
You will have to wait on M1.
PostPosted: Tue Aug 09, 2011 5:16 pm
by als
but is not possible in other mode?
i know jaguar xfr and porsche panamera in superstars series use motec and they have direct injection
PostPosted: Tue Aug 09, 2011 6:24 pm
by AlanB
I believe the cars running in Superstars use an external driver box for the injectors.
You should contact Avio Race (details are on the website) for more information. They should be able to help you.
PostPosted: Tue Aug 09, 2011 11:04 pm
by als
yes i know they have external module but i would know if motec have any solution or who product of external module?
PostPosted: Wed Aug 10, 2011 2:44 pm
by Gaston
Als, this isnĀ“t so difficult.. In case the difference between a "Old injectors" and FSI (direct injector) is just voltage working... m very interested on working with TFSI engines.... I suppose you just need to build an electronic oscilator with rectifier to "transform" 12Volts to 70 volts (I believe this is the volatge necessary to drive a FSI injector)... After this stage a good Darlinton transistor driver between Motec Ecu signal and FSI Injectors.
This would work same as Ignition module, but with More voltage !... Do you know what I mean?
PS.. This is just my idea ! :idea:
Cheers !!!
PostPosted: Mon Aug 15, 2011 10:38 pm
by als
i have look his system, is similar at your idea but i need more info
