Simple Boost Control On V3.5
Postby uvii on Thu May 26, 2011 7:50 pm
Can I just confirm that having values in the Normal Table for Simple Boost Control prevents boost control working. It says in the Help screen that all tables a part from Aim Boost should be '0' for Simple Boost Control.
I have never had issues before with having values in other tables when using Simple Boost Control but recently lost the ability to make boost over the spring rate....
uvii
Re: Simple Boost Control On V3.5
Postby MarkMc on Fri Jun 10, 2011 5:50 pm
In V35 you need to make sure the control channel is set to 6 for open loop boost control. Proportional Gain needs to be 1. All other Gain tables and Integral calmps need to be 0. The min and max duty table still need to have something.
Return to Tuning discussions
