Standalone pressure logging devices?
Postby Chris Wilson on Thu May 12, 2011 9:10 pm
I often have customer cars in that may not be performing as anticipated. Most will not be running a Motec, or even an aftermarket ECU. I would like to be able to measure and log exhaust system back pressure, and across intercooler and air filter pressure drops. Has anyone coma across a basic, cheap and easy to use data logger that's quick to set up for measuring this type of thing? The ability to log temp probe outputs would be nice, too. Real time display an added advantage. Thanks.
Chris Wilson
Re: Standalone pressure logging devices?
Postby stevieturbo on Sat May 14, 2011 7:51 am
Setup alone with adding takeoffs for each item will mean it's never a quick thing to do.
Not sure any such setup will be cheap, but I'd imagine some of the Innovate stuff is at the cheaper end of any such devices.
LMA-3 or their DL-32 dont seem overly expensive though. In fact, they seem quite cheap. Not sure how ready to go they are though.
Return to Tuning discussions
