Pro tunners, what do you do when...
As a pure amateur and mostly for fun, I installed Motec ecus on my mate's bike and on mine.
I was requested to install and tune a car for a friend's customer. My friend is a pro, but is not able to setup electronics. I was paid for this and the setup was clean and the car runs well, proven by lots of datalogs. The motor build was also very good. We are all sure we did everything as it should be and the customer was happy.
After some races with medium results due to drivers being faster
, the customer was told by others that "his car could be better, faster, motor should be rebuild and remapped, blabla".
If this car go to another builder, it is clear for me I am not responsible anymore of what will append after this rebuild. It is clear also I would not work anymore on the new setup to improve it, add options, etc....to avoid problems with new tuner.
My question to you, pro builders, tuners and so on: what do you usualy do in this situation?
Thanks for your kind advises
Angelo
Angelo
