Lambda closed loop control x 3
So finally last night I switched on the Lambda closed loop control for my 20B rotary engine after playing with the mixtures and idle valve for several months now, I was happy with the idle mixtures before but after running the closed loop they are simply perfect now.
Almost a straight Lambda trace line with it only ever deviating 0.01 either way, very happy
What a difference this makes just to smooth everything out nicely and take control of any little adjustments. Many thanks to forum user Martin who showed me how to data log the channels to work out Lambda delays and then setup the settings to control it, one more reason Motec is worth the extra money and effort !
My question is now that I have 2 lambda sensors controlling rotor 1 and rotor 2 individually with closed loop can I control rotor 3 via closed loop when I purchase a LTC ?
This would be a perfect setup rather than having a 'dumb' lambda sensor that cant make any fuel corrections while the other two can.
Does Motec plan to control more than 2 lambda sensors via closed loop in the future ? Will these be a software or hardware restriction ?
ECU is M800.
ECU is M800.
