No Lambda Control issue
Postby whrdnsx on Sun Aug 01, 2010 5:20 pm
I have a strange issue. Lambda control has stopped working for some reason.
I have M800 with PLM connected via can. (NTK sensor)
I still see lambda on the PLM & ECU manager but the short & Long trim has stopped working.
I checked my Logs & have no conflicting operations Ie Accel enrich ect but no closed loop/lambda trim.
I do however have a Lambda error on the logs recently that appeared during normal running (cruise) & error group 1 shows NO. 16 not sure what that means? However the lambda reading on the log seemed to be fine?
I have been watching every parameter to do with Lambda on ECU Manager whith the engine running & everything shows normal, but lambda control will not turn on.
Am I missing something?
whrdnsx
Return to Tuning discussions
