I am trying to solve an irritating issue with the fueling of my Evo which is equipped with a M800. I spent a fair bit of time leaning it out to achieve better fuel economy during part throttle and cruising conditions...basically anytime when the car is off boost. The problem is that the lambda values seems to drift every now and then without any changes in the map. For a couple of days, the lambda sensor might be showing 1.03 for the 2500RPM/50KPA cell and then suddenly, it might go to .85 in the same cell the next day and stay that way for a few days before reverting to the original value. The drifting happens more often during partial throttle conditions but it happens during warm idling as well.
I'm at sea level and the ambient temperature right now is quite constant (+/- 2 Celsius...averaging 34 Celsius). The datalogs show the fuel pressure to be stable so the fuel pumps (Bosch 044) and injectors (Bosch EV14s) should be ok. Battery voltage is stable as well. There's neither temp/pressure compensations nor accel enrichment activated on the fuel/ign maps so the fueling should really be consistent. The lambda reading comes from the single lambda option in the M800. What do you think could be the issue?
Rgds,
JR
