Piston failure
Piston failure
Postby Mazi on Thu Jul 08, 2010 10:02 pm
VAG BAM engine (Audi S3 1.8 turbo), GT3076R, M800
435HP-490Nm and hole in the piston...
Piston failure 1.jpg (124.2 KiB) Viewed 23783 times
Mazi
Re: Piston failure
Postby Martin on Fri Jul 09, 2010 4:22 am
I like the boost!
wheres the Ign timing? :)
Re: Piston failure
Postby Mazi on Fri Jul 16, 2010 6:35 pm
It was 3-4deg during "high boost".
Boost is flat and nice :) Sensor is Bosch 400kPa with integrated AT sensor. Wastegate control valve is E75 stock VW and is working perfect. There was no pain to set up PID and tube network this time.
Mazi
Re: Piston failure
Postby Martin on Sat Jul 17, 2010 12:52 am
What wastegate are you using?
As far as I know you get the 3076 in both internal and external?
Re: Piston failure
Postby Mazi on Sat Jul 17, 2010 6:36 am
Internal one.
Actuator is 52mm diameter from the stock setup with modified mounts. There is no place behind the engine to fit bigger one.
Audi S3 Turbo.jpg (324.64 KiB) Viewed 23663 times
Mazi
Re: Piston failure
Postby Martin on Mon Jul 19, 2010 3:33 pm
very nice
Re: Piston failure
Postby fel1979 on Tue Jul 20, 2010 12:00 am
Is it possible to share more data?
Like Ign advance, Duty Cycle, knock?
What fuel were you running and Specs.
Why do you have that flutuation with the lambda, if your boost was stable?
Are you running hi/lo injectors?
If you could add the log file it will help to understand the whole picture.
Regards
fel1979
Re: Piston failure
Postby Mazi on Thu Jul 29, 2010 6:51 pm
It wuz bloody 1000ccm injector... :evil:
Hole where the middle inlet valve take place
BAM S3 Hole.jpg (457.31 KiB) Viewed 23483 times
No damage!
BAM S3 Head.jpg (416.44 KiB) Viewed 23487 times
Mazi
Return to Tuning discussions
