Brake Bias Question
Why would a pedal box do this? Any Ideas what could be wrong?
Single seater with push master cylinders
The official support forum for MoTeC products
https://forum.motec.com.au/
Scott@FP wrote:What are the ratios from master cyl bore to caliper bore(s)?
The rears will usually have a lot less caliper bore.
Also you may be seeing a lot of caliper flex, especially when hot.
Mazi wrote:Diameter of master cylinders are the same? Bigger one should be connected to the rear calipers.
If there is a single master cylinder then closer one to the push rod must be connected to the front calipers.
Martin wrote:Mazi wrote:Diameter of master cylinders are the same? Bigger one should be connected to the rear calipers.
Master cylinders are different in size, and yes the bigger diameter is to the rear.
The problem is that it was always okay, and something changed but I cant tell what. Any suggestions what kind of failure could cause this?
