Bosch 0 280 158 117?
Wed Apr 14, 2010 9:53 am
by stevesingo
Does anyone have accurate battery comp info for these injectors?
Many thanks
Steve
Re: Bosch 0 280 158 117?
Wed Apr 14, 2010 4:36 pm
by DarrenR
What car and engine are they from?
Do you know how much they flow??
Wed Apr 14, 2010 6:21 pm
by stevesingo
52 lb @ 3Bar High Impedance EV14 style. As for what car, I have no idea.
Steve
Sun Apr 18, 2010 12:37 pm
by yotamhks
a search with google gave me these details if it helps:
http://www.fiveomotorsport.com/import-high-performance-fuel-injectors/?itemid=352- Code: Select all
48 lbs/hr 500 cc/min EV14-WRX, Tiburon Injectors 14.5 Ohms Bosch 0280158117
Fri Sep 26, 2014 2:27 pm
by Allan
also looking for data on these, used in Ford GT500 as well...
http://www.bmotorsports.com/shop/produc ... ts_id/1661
Sat Oct 25, 2014 8:48 pm
by Holmz
Wow Steve nailed that.
Are you running a fuel pressure sensor?
If so then you could take advantage of any pressure starvation with those values... Up to a point.
And at that point turning off the injectors would probably be the safest bet for known lambda.
Maybe AFR of 17+ is OK?, but the danger zone at WOT is around .95-1.1 I think (???), after one gets well lean, then it gets good again.
