Bosch 0 280 158 117?
Postby stevesingo on Wed Apr 14, 2010 9:53 am
Does anyone have accurate battery comp info for these injectors?
Many thanks
Steve
stevesingo
Re: Bosch 0 280 158 117?
Postby DarrenR on Wed Apr 14, 2010 4:36 pm
What car and engine are they from?
Do you know how much they flow??
Darren Reynolds
DarrenR
Postby stevesingo on Wed Apr 14, 2010 6:21 pm
52 lb @ 3Bar High Impedance EV14 style. As for what car, I have no idea.
Steve
stevesingo
Postby yotamhks on Sun Apr 18, 2010 12:37 pm
a search with google gave me these details if it helps:
http://www.fiveomotorsport.com/import-high-performance-fuel-injectors/?itemid=352
Code: Select all
48 lbs/hr 500 cc/min EV14-WRX, Tiburon Injectors 14.5 Ohms Bosch 0280158117
yotamhks
Postby Allan on Fri Sep 26, 2014 2:27 pm
also looking for data on these, used in Ford GT500 as well...
http://www.bmotorsports.com/shop/produc ... ts_id/1661
Allan
Postby stevesingo on Fri Sep 26, 2014 6:59 pm
stevesingo
Postby Allan on Mon Sep 29, 2014 3:29 pm
Champion! thank you!
Allan
Postby Holmz on Sat Oct 25, 2014 8:48 pm
Wow Steve nailed that.
Are you running a fuel pressure sensor?
If so then you could take advantage of any pressure starvation with those values... Up to a point.
And at that point turning off the injectors would probably be the safest bet for known lambda.
Maybe AFR of 17+ is OK?, but the danger zone at WOT is around .95-1.1 I think (???), after one gets well lean, then it gets good again.
Return to Tuning discussions
