hello,
how can i find out optimal injection timing when i use secondary injectors?
the values in my actual map are from an older engine (before i bought the car, the maps were in the ecu).
now we have an other inlet and a higher compression ratio. it is a turbo engine with about 500hp.
end of injection is chosen.
at 1000 rpm i have 40 degrees, 2000rpm 60 degrees and so on.
the secondary injetion has 150 degrees at 1000rpm, 220 at 3000rpm...
i read some postings in this forum, but i do not know how i can optimize it for the new engine.
should i adjust it in the neutral gear every 500 rpm or does engine load has an effect?
the secondary injection only is active at high load(50:50 at 300kPa), how can i get the right values?
thanks for your help.
regards
fetzi
