Direct injection
Direct injection
Postby als on Fri Aug 05, 2011 4:30 am
Hi at all..someone have install motec engine managment in any petrol car with direct injection?
How did you manage the high voltage injectors?
Thanks at all
Luca
als
Re: Direct injection
Postby Gaston on Fri Aug 05, 2011 1:39 pm
Hello Als !
Is this a Common Rail Diesel Engine ? Or FSI (regular fuel) Engine ?
Gaston Scazzuso
whatsapp: +54(9)11 5385 1996
mail: soporte@moteclatinoamerica.com
Gaston
Postby als on Fri Aug 05, 2011 5:55 pm
is a regualr fuel egnine type FSI
als
Postby als on Mon Aug 08, 2011 6:07 pm
someone have any suggestion?
als
Postby Mazi on Tue Aug 09, 2011 12:10 am
You will have to wait on M1.
Mazi
Postby als on Tue Aug 09, 2011 5:16 pm
but is not possible in other mode?
i know jaguar xfr and porsche panamera in superstars series use motec and they have direct injection
als
Postby AlanB on Tue Aug 09, 2011 6:24 pm
I believe the cars running in Superstars use an external driver box for the injectors.
You should contact Avio Race (details are on the website) for more information. They should be able to help you.
Alan Bell
MoTeC Europe Ltd
AlanB
Postby als on Tue Aug 09, 2011 11:04 pm
yes i know they have external module but i would know if motec have any solution or who product of external module?
als
Postby Gaston on Wed Aug 10, 2011 2:44 pm
Als, this isn´t so difficult.. In case the difference between a "Old injectors" and FSI (direct injector) is just voltage working... m very interested on working with TFSI engines.... I suppose you just need to build an electronic oscilator with rectifier to "transform" 12Volts to 70 volts (I believe this is the volatge necessary to drive a FSI injector)... After this stage a good Darlinton transistor driver between Motec Ecu signal and FSI Injectors.
This would work same as Ignition module, but with More voltage !... Do you know what I mean?
PS.. This is just my idea ! :idea:
Cheers !!!
Gaston Scazzuso
Gaston
Postby als on Mon Aug 15, 2011 10:38 pm
i have look his system, is similar at your idea but i need more info
als
Return to Tuning discussions
