I am a student working on tuning an Aprilia sxv 550cc v-twin engine for a school project.
We are currently unable to use any iacv for idle, and I am very interested in your thoughts on the best way to maintain a stable idle as well as stall prevention after any sort of throttle input (un-loaded of course).
Currently we have created an ignition "trough" to hold the idle at 3000rpms (oem is around 2200). However we are having trouble going lower.
This trough also prevent the motor from stalling after throttle input as it was before the trough was created. However this is a little dodgy as sometimes it does stall and I would much prefer to get rid of that.
This is assuming the motor is at temperature, we are calculating load with TPS vs RPM only. Running a very small restrictor also.
I am curious if accel and decel enrichment can be used to help prevent stalling and perhaps allow us to not depend so much on the ignition trough we have thus far.
Any advice is greatly appreciated as we are taking this step by step but it is very difficult with no real detailed manual.
Thanks!
