Hey gang,
I'm stuck on a few fuel system design questions and I'm hoping for some help.
The main question is, will my OEM hard lines (3/8" OD Supply/ 1/4" OD Return), cause starvation at 15 psi boost?
Recap:
I'm installing a new 2.2L naturally aspirated motor, with plans to supercharge it in the near future (discretionary spending pending). All my current purchase/ installation decisions are about future proofing for an easy transition to SC.
My existing fuel system is a bit convoluted, but worked fine with the prior 2.2 NA motor (i.e. Fuel pressure, 46psi, was static at all RPMs):
The system starts with a modified OEM gas tank where I've welded in a 300ZX in-tank fuel pump (Bosch 67867). I can't seem to find any official flow data on this, but users say it can flow around 200-260 lph and 80+ psi, and can support applications up to 500-600 HP.
Fuel leaves the ZX pump via a -6 hose, then mates to the OEM hard fuel lines by way of a -6 to -4 conversion. This OEM supply hard line is 3/8" OD. Once this gets to the front of the car it jump back from a -4 fitting to -6 Earl fuel filter, then -6 hose all the way to the -6 fuel rail.
The end of the fuel rail has a non-referenced -6 fuel pressure regulator mounted on it (which will change to referenced, once I go SC).
It comes out of the regulator via -6 hose until it once again hits the return OEM hard line, which is only 1/4" OD.
At the back of the car it once again converts from -4 fitting to -6 hose up to the fuel pump return port.
I recently upgraded my old 31lb GM fuel injectors to a more precise set of Injector Dynamics ID725s. These should easily cover the target 375-400 RWHP I'm hoping to make. I also bought their ID F750 (5 micron) fuel filter with dual sensor (http://injectordynamics.com/id-f750-fuel-filter/), this has -8 inlets and outlets.
Since this new fuel filter has -8 inputs and outputs, and I'm upgrading my hose, I figure it's time to challenge my assumption on hose size (-6 has to be plenty for 400HP), not only in the engine compartment, but considering the possibility of replacing the OEM hard lines (the possible bottle neck).
I'm targeting 15psi of boost for the SC set up, so assuming I'll be running an effective injector pressure of 46psi again, I'd have to run the rail pressure at 61psi?
I'm thinking the 3/8" OD supply (5/16" ID?) could be fine but the 1/4" supply might need replacing?
I'd prefer to troubleshoot on paper vs during an expensive dyno session. Any thoughts or experience on how to solve for this?
Thanks,
Cory
