Logging at thermostat housing, engine is 4G63.
Temp and pressure sensors opposite each other approx 50mm apart.
Would it not be likely to see short lived pressure spikes during a sweep through a gear as manifold pressure and revs rise, because of localised hot spots around the cylinders?
Perhaps only the pressure sensor seeing this but the temperature spikes dissipating due to the volume of water?
