Maybe someone will find this interesting.
Graph of base igntion map then -3deg, -6deg, -9deg, -12deg, -15deg, -18deg, -21deg
No boost control was done. Its just open loop DC with a boost reference. DC in all runs the same.
Martin wrote:What you are seeing....
Most timing, Most power, Least boost
Less timing = Less power = More boost (this is the case for each of the graphs, -3. -6, -9, etc....)
Yes, EGTs would have been good. Cylinder pressure with TDC reference brilliant.
