MoTeC are proposing a kit for the SHO engine
The Kit would consist of
1 X M400 ECU, including the drive by wire upgrade
Plug in adapter loom
ECU Mount brackets and securing screws
Anyone can fit it and it can be changed over in way under an hour.
We are aiming to supply this with a file that should increase at least 30 HP over the standard ECU
The following items currently do not work from the std ECU
Reverse traction control
All Cruise control functions
No Wake Mode
RPM on the standard Dash
