Goldwave settings
What sampling rate is best for the Goldwave software? My knock window signal is not true square wave (will try and post a screen capture when I can). Starts as a square wave on the rising edge, but then tapers for part of the falling. The actual knock signal data looks pretty normal.
I also get the occasional INJ8 open error, though not all the time.
M800 ECU, waste fire 10 cylinder engine. It is also an odd fire engine if that changes things.
