SKM on Rotary
SKM and OKM
SKM on Rotary
Postby Martin on Thu Feb 12, 2009 4:36 pm
What should the knock window angles be on a rotary?
Re: SKM on Rotary
Postby PeteS on Thu Feb 19, 2009 10:06 am
Hi Martin
I am not sure of the exact answer here as I dont have a record of doing it.
As a starting point thou I would use 0 and 50
The rotary engine is very quiet and you should easily be able to hear a detonation event.
Obviously record this into Goldwave and close the window around the measured knock event.
We will be interested in your results
Regards
Pete
MoTeC Research Centre, Melbourne Australia
PeteS
Return to Knock Modules
