SKM Use
SKM and OKM
SKM Use
Postby killerbee on Mon May 09, 2016 3:34 pm
Can the SKM be used as a knock detector and logged using a Motec dash ? I do not have a motec ecu for this application.
killerbee
Re: SKM Use
Postby killerbee on Sun May 22, 2016 1:06 pm
Well I gave up going that route. I will use the skm with my M800. For the application I wanted to use it for, E30 BMW 325i with the ancient Bosch Motronic 1.3 I got a plex unit (http://www.plex-tuning.com/products/ple ... r-v2-0-new). Works well and is easy to install and use. Very flexible device.
killerbee
Return to Knock Modules
