Default OKM settings for 06-07 WRX STI (2.5L)
SKM and OKM
Postby mrsaturn7085 on Sat Apr 09, 2016 11:43 am
I recently purchased an OKM to retrofit to a WRX9-10 board. Default jumper settings are as follows:
Differential Mode Switch = off; normal knock sensor connection (default)
Gain = 2 (default)
Knock Centre Frequency = 10 kHz (default)
Could you please provide the correct default jumper settings for the following application:
06-07 Subaru WRX STI w/EJ257 (2.5L, single AVCS) motor
Motor is completely stock internally, with only minor external modifications (open exhaust, panel air filter).
mrsaturn7085
Re: Default OKM settings for 06-07 WRX STI (2.5L)
Postby SprinterTRD on Mon Apr 11, 2016 9:41 am
Use 14Khz for the knock frequency. Then read the SKM/OKM user manual, it has detailed instruction on how to use the SKM/OKM
Postby mrsaturn7085 on Tue Apr 12, 2016 3:14 am
14kHz - thank you.
Do you know the default gain jumper setting?
I have read the OKM/SKM manual cover-to-cover three times, and I'm just trying to start with the same baseline that this board would ship with for my application.
mrsaturn7085
Postby SprinterTRD on Tue Apr 12, 2016 10:06 am
Most OEM sensors work with the standard gain settings so no need to change them.
Return to Knock Modules
