Knock Sensor Selection outputs - M400
Hi
Im using a M400 (3.54E) for knock monitoring. Im using a home made/designed knock module based on the TI TPIC8101 and a Microchip controller. This works very well using a single knock sensor, but now Id like to explore
using multiple sensors. For this to work I wanted to use the new "Knock Selection" function in 3.54E, eg function 139/140 on a pair of Aux outputs.
As a test, using Aux 1 and function 4 (tacho) with a 2k2 pullup to 5V, I can see a clean pulse as expected, however setting the function to 139 (Knock Sensor select 1) I cant see any output from the Aux port. In fact is appears to be in high-impedance mode. Has anyone successful used these new functions (139/140) yet, and if so got any advise on how to set them up and enable them.
Notes on the setups:
From a working single knock sensor system...
Function->Knock Control->Sensor Cylinder. Definded cylinders 1/2 on Sensor 1, and cylinders 3/4 on sensor 2
Aux Output Functions -> Aux Output 1 Function 139
Aux Output Functions -> Aux Output 2 Function 140
Adam
Adam
