3 wire sensor connections
SKM and OKM
Postby stevesingo on Fri May 21, 2010 6:03 am
I have a Bosch Knock sensor 0 261 231 047 which has 3 wires.
Pin 1 Sig +
Pin 2 Sig -
Pin 3 Shield.
Can this be connected to an SKM? I was thinking of either wiring the shield and Sig - together or connecting the Sig - to the ECU sensor 0v.
Any suggestions?
Steve
stevesingo
Re: 3 wire sensor connections
Postby Mazi on Sat May 22, 2010 12:54 am
Sensor Pin 1 Sig+ --> Sensor 1 input SKM Pin 6
Sensor Pin 2 Sig- --> Sensor 3 input SKM Pin 8
Sensor Shield Pin 3 --> SKM sensor shield Pin 10
DM switch must be ON for Differential mode.
Mazi
Postby stevesingo on Mon May 24, 2010 2:36 am
Thanks.
Any Pros/Cons of 2 wire vs 3 wire sensors?
Steve
stevesingo
Postby Mazi on Mon May 24, 2010 4:44 am
3 wire differential design is by definition less sensitive to the EMI noise.
Mazi
Postby stevesingo on Mon May 24, 2010 6:14 am
Thanks.
So the better option then?
Steve
stevesingo
Postby Wolf_Tm250 on Mon Dec 03, 2012 5:23 am
I'm trying to connect a 2 wires Bosch 0-261-231-006 ks, but SKM manual is not so clear.
I was told by the seller that the 2 wires are Sig+ & Sig-, as the shield is only in the cable, so does this mean it is a differential sensor too and have to connect the 2 wires to SKM input 1 and 3, or it is just Sig+ and ground?
Thanks in advance
Wolf_Tm
Parma - Italy
Wolf_Tm250
Postby YuriK on Mon Dec 03, 2012 4:38 pm
You need to wire the sensor exactly as it is shown in the SKM manual Signal goes into SKM pin 6 and 0V (or Sig-) goes into SKM pin 10.
BTW I checked come 3 wires Bosch knock sensors and they all seem to be just two wires and shield sensors, didn't see any truly differential knock sensors.
Regards!
YuriK
Postby Wolf_Tm250 on Mon Dec 03, 2012 6:03 pm
YuriK wrote:Hi,
Regards!
Yuri,
as you can see in the manual, Pin 10 is "black/shield" and not "knock sensor ground", that's why I was unsure.
So if I wire 0v to Pion 10, where to wire cable shield?
Thanks in advance.
Wolf
Wolf_Tm
Parma - Italy
Wolf_Tm250
Postby YuriK on Tue Dec 04, 2012 9:44 am
Hi Wolf,
You can wire the sield to pin 13 or put it on chassi ground
Regards
YuriK
Postby Wolf_Tm250 on Tue Dec 04, 2012 7:32 pm
YuriK wrote:Hi Wolf,
Regards
Thanks a lot!
Regards
Wolf_Tm
Parma - Italy
Wolf_Tm250
Return to Knock Modules
Users browsing this forum: Bing [Bot] and 5 guests
