GPS laptiming problem
Wed May 27, 2009 4:00 am
by thorstengsxr
Hi
Last weekend I was in Most(cz) and I had a problem with GPS laptiming. I have a ADL2 and a Bl1.The problem was a can't insert the finishingline when i insert the longitude for exampel 13.6003322 or 13 36 1,20 E the programm ignor the data
when I change East to West it work fine but Most is East and a lot of racetracks in europa too.
Is this a bug, or did something wrong?
Regrads Thorsten
Re: GPS laptiming problem
Wed May 27, 2009 3:55 pm
by JamieA
can you please put up a screen shot of what you are trying to enter, and in what screen so that I can get a better understanding of what you are doing..
thanks.
Wed May 27, 2009 4:50 pm
by thorstengsxr
HI
Her is what i men the gps data comes from the ADL2 logging
regrads Thorsten
Thu May 28, 2009 2:55 pm
by JamieA
ok, So you type in that latitude and longatude as shown in the screen shot, then what happens?
Does it not accept those numners?
does it change them when you go back and check?
Does it not save them?
Does it now work as a beacon when you send this to the dash?
thanks.
Thu May 28, 2009 4:32 pm
by thorstengsxr
Hi Janie
Hi i write the data into the fields and close the window and the software write's nothing into the list. No error or warining. I make a nother test this evening and use the finishingline of the lausitzspeedway in germany, and i had the same problems .
regrads Thorsten
Fri May 29, 2009 9:03 am
by NathanS
This sounds like it is to do with the regional language options setting on your laptop, if you go to Start > Control Panel > Regional and Language Options and then change the Standards and Formats to English (UK) you should now be able to enter the coordinates.
Fri May 29, 2009 4:13 pm
by thorstengsxr
Hi
Wonderfull this was my mistake. now it works fine
thanks and regards Thorsten
