GPS laptiming problem
Postby thorstengsxr on Wed May 27, 2009 4:00 am
Hi
Last weekend I was in Most(cz) and I had a problem with GPS laptiming. I have a ADL2 and a Bl1.The problem was a can't insert the finishingline when i insert the longitude for exampel 13.6003322 or 13 36 1,20 E the programm ignor the data :cry: when I change East to West it work fine but Most is East and a lot of racetracks in europa too. :D Is this a bug, or did something wrong?
Regrads Thorsten
thorstengsxr
Re: GPS laptiming problem
Postby JamieA on Wed May 27, 2009 3:55 pm
can you please put up a screen shot of what you are trying to enter, and in what screen so that I can get a better understanding of what you are doing..
thanks.
JamieA
Postby thorstengsxr on Wed May 27, 2009 4:50 pm
HI
Her is what i men the gps data comes from the ADL2 logging
regrads Thorsten
thorstengsxr
Postby JamieA on Thu May 28, 2009 2:55 pm
ok, So you type in that latitude and longatude as shown in the screen shot, then what happens?
Does it not accept those numners?
does it change them when you go back and check?
Does it not save them?
Does it now work as a beacon when you send this to the dash?
thanks.
JamieA
Postby thorstengsxr on Thu May 28, 2009 4:32 pm
Hi Janie
Hi i write the data into the fields and close the window and the software write's nothing into the list. No error or warining. I make a nother test this evening and use the finishingline of the lausitzspeedway in germany, and i had the same problems .
regrads Thorsten
thorstengsxr
Postby NathanS on Fri May 29, 2009 9:03 am
This sounds like it is to do with the regional language options setting on your laptop, if you go to Start > Control Panel > Regional and Language Options and then change the Standards and Formats to English (UK) you should now be able to enter the coordinates.
NathanS
Postby thorstengsxr on Fri May 29, 2009 4:13 pm
Hi
Wonderfull this was my mistake. now it works fine
thanks and regards Thorsten
thorstengsxr
Return to GPS Information
