Can you make sure that you have the following setup in the Dash.
This is in the CAN Templates
- GPS to M1.PNG (2.91 KiB) Viewed 8681 times
RS232
- GPS receive.PNG (1.96 KiB) Viewed 8681 times
By using these templates the GPS Valid signal will be generated, allowing for the M1 Lap Timing to work.
The FAA mode is not supported with these templates so remains as Unknown, this does not affect the operation of the M1.
