FAA mode=invalid
FAA mode=invalid
Postby Doorev1200 on Sun Sep 13, 2020 9:46 am
I just installed a c127 dash to my m1 system. I did all the necessary can msgs with the gps to m1 and such. It seems to work but I am getting a invalid FAA mode msg and unknown valid. Is this because it is in my shop and can not get a good reception? (i cant get the unit outside ATM) All other info seems good. I hope its just the fact its inside??
motec screen shot.jpg (192.22 KiB) Viewed 10388 times
Doorev1200
Re: FAA mode=invalid
Postby Stephen Dean on Mon Sep 14, 2020 5:06 pm
Can you make sure that you have the following setup in the Dash.
This is in the CAN Templates
GPS to M1.PNG (2.91 KiB) Viewed 10355 times
RS232
GPS receive.PNG (1.96 KiB) Viewed 10355 times
By using these templates the GPS Valid signal will be generated, allowing for the M1 Lap Timing to work.
The FAA mode is not supported with these templates so remains as Unknown, this does not affect the operation of the M1.
Postby Doorev1200 on Thu Sep 17, 2020 1:49 am
I will double check and make sure. Thank you!
Doorev1200
Return to GPS Information
