Is GPS out of M800 serial / CAN untouched or filtered?
Is the GPS from the 5Hz Motec GPS receiver output totally unfiltered via RS232 into an M800? Why do I ask? If I log it internally via the M800 itself the results in i2 are fine, if I log it via CAN to A N Other standalone logger there are spikes in the rendered map until the vehicle / GPS receiver is moving. It's unfair to ask you to help with A N Other logger, but will you just tell me if the output of the 5 Hz receiver is manipulated or filtered in any way before being either logged internally in the ECU or spat down the CAN bus via a custom data set?
Thanks.
Thanks.
