GPS Beacon issue ADL2
Hey,
I have a GPS-System running on ADL2. Working fine so far. Wanted to try the GPS-Beacon feature and did not get it to work.
GPS lat/long values I have taken from logged data and inserted the values as beacon position in the ADL2 config. Then checked it with the "online->view->GPS-beacon-definitions" feature and everything was correct. But I didn't get a beacon when I passed this point. Even when I tried different "detection radius" values (5m -> 25m).
When I open the logged data in i2Pro and use the "auto-insert beacon by GPS " function and use the same coordinates that I entered in the ADL2 config, i2Pro automatically inserts the beacon absolutely correct.
GPS track map and everything else works fine. Just the beacon makes trouble. Any ideas?
DM V4.51i
cheers,
Robin
PS: just read that you need at least a 5Hz system for the beacon function. My GPS only has 4Hz, is this really the problem?
DM V4.51i
cheers,
Robin
