Chris Wilson wrote:Thanks for the reply, I may be interested in your GPS unit, how much would you be wanting for it, plus it would need sending to me here in the UK? Thanks. E-mail me direct if you prefer, I am at chris@chriswilson.tv Cheers.
Polux RSV wrote:Another question is why 20Hz ? and even 5Hz?
GPS alone is not precise and repetitive enough for "line" and "trajectory" analysis.
In i2, I use track mapping only to know where motor and driver "events" are located on the track.
The only advantage to use 5, 10 or 20Hz is when GPS speed is used in real time, for traction control as an example.
Angelo
