MDC2 to ECU Input table
Postby alquick on Sat Oct 24, 2009 9:55 pm
Hello! where can I find the MDC2 Data Vs ECU input table like in the MDC user manual pag 18?
Thanks!!
alquick
Re: MDC2 to ECU Input table
Postby RossB on Tue Oct 27, 2009 9:42 am
This information is sent via CAN for the MDC2. The M800 start file for the EVO X is set up to transmit a data set to the MDC2 which includes these channels. If you want to use Efficiency Point as your table axis in the MDC2 you can change this in MDC2 Manager by going to File/Setup/User Modes and selevting ECU Efficiency for thr Lock Table Axis.
Return to MDC and SDC
