SDC - Flashing lights on dash
Postby Dave S on Tue Jul 28, 2009 3:17 pm
Hi
Finally bought a SDC for my 2004 MY05 AUD STi.
On start up the mode indicator lights on the dash flash. If I drive around the road they continue to flash and it does not feel like the controller is working - I can select locked and it works. On dirt sprints over the weekend - short stages of about 3 to 4klms the lights would at some time during the stage stop flashing and the controller would work. I wasn't conscious of the change at the time but I remember thinking that the tyres gripped up about 1/2 way into the stage (after a fast section (about 140kph)) so I assume this is when the controller started.
Each time I start the car up again the lights flash again and at the end they were not flashing.
This morning I drove on the road for about 10k's on the road up to 100kph and the lights were still flashing. I ran the thumb wheel through to locked then back to open and the lights stopped flashing.
In the monitor channels section it gives a fault code of 8 for Output Driver Failure and a diagnostic flag of 16 for Steering Angle Sensor not present on vehicle CAN bus. I haven't checked the channels after the lights stop flashing to see if there are error codes.
My car doesn't have a steering sensor so that part would sense.
Does anyone have any suggestions as to what I have done wrong or how to fix it.
Dave
Dave S
Re: SDC - Flashing lights on dash
Postby RossB on Wed Jul 29, 2009 9:55 am
The Diagnostic Flag for the steering sensor will not cause the lights to flash but the Fault Flag for the Output Driver Failure will.
It is possible that there is a problem with the setup or the wiring. Check that ytou have the default settings in the Output Setup of your configuration, they should be:
Full Lock Current: 5.0A
Min Pulse Width: 80 uS
Max Pulse Width: 800 uS
Output Current Protection: 11A
Also check that the wiring to the solenoid hasn't been damaged.
Postby Dave S on Thu Jul 30, 2009 4:07 pm
Hi Ross
The program I am running has
Full Lock Current: 6.5A
Output Current Protection: 7.5A
and the default for the SDC2 is
Output Current Protection: 7A
I will try the settings when I get the car back tomorrow, just to confirm the Output Current Protection should be 11A not 7A.
Thanks for your help
Dave
Dave S
Postby RossB on Thu Jul 30, 2009 5:03 pm
11A is the correct default.
Postby Dave S on Thu Aug 06, 2009 5:06 pm
Thanks Ross
I have loaded the output configurations you gave me and it still flashes. I did run a program to test the maps work and they do.
The program doesn't seem to lock as hard as the factory program - although it has been a couple of years since I drove it in lock as a test.
I'll check the wiring this week end.
Dave
Dave S
Postby Dave S on Sat Aug 22, 2009 1:35 pm
Hi
Checked all the wiring and they tell me it's all Ok.
I've tried a few different maps and set ups but it still behaves the same way. Flashes then if I drive it for a short distance and scroll through the settings it stops flashing and starts working but does it work properly ?
Dave
Dave S
Postby RossB on Mon Aug 24, 2009 9:23 am
I think it would be a good idea to return toe SDC to your dealer so that it can be sent to us for testing. This is an unusual problem.
Postby Dave S on Thu Apr 15, 2010 5:26 am
Hi Ross
I have my SDC2 back and fitted. Problem solved, thanks
Dave
Dave S
Return to MDC and SDC
