SDC2 OEM Connector Wiring Tools
Postby paradigmshift on Mon May 15, 2023 4:03 pm
I am installing a SDC2v into a JDM Sti RA MY99, adding in wheel speeds sensor etc.
My biggest challenge is in removing contacts from the OEM Connector. I have all new shells and contacts but extracting a contact is nigh on impossible, there HAS to a better way.
Could anyone recommend a tool to de-pin this style of factory connector.
https://au.mouser.com/ProductDetail/571-316372-6
Uses these pins https://au.mouser.com/new/te-connectivi ... multilock/
Simon
paradigmshift
Re: SDC2 OEM Connector Wiring Tools
Postby paradigmshift on Mon Jun 19, 2023 3:34 pm
And solved
The SDC plug is similar to the Subaru OEM ECU connectors. Turns out i needed skills not extra tools.
This video https://www.youtube.com/watch?v=QE7DdnD9cto (how to depin an ECU connector) show the technique.
paradigmshift
Return to MDC and SDC
