MDC diff pump request output via CAN
Dear MoTeC team,
is there a chance to add diff pump request output to the CAN stream of the MDC (same mirrored signal like pin 16 - Pump relay output), maybe added to the existing diagnostic flags CAN frame?
The purpose would be to activate a pump via CAN and keep all the pump logic that you already have inside the MDC (with manual bleed override, safety timeout and so on).
I imagine the MDC's become older yet they are still used for new builds that do all the stuff via CAN nowadays.
Kind regards,
Mike
Kind regards,
Mike
